Maintenance Page iRule and other iRule Conflicting.
The original maintenance page irule is as follows and works by itself:
priority 400
if { [active_members /partition/poolname_pool] < 1 } {
HTTP::respond 200 content [ifile get "poolname_MaintenancePage_ifile"] noserver "Content-Type" "text/html" "Cache-Control" "no-cache, must-revalidate"
However, when this next irule is attached to the VIP, a "Page Cannot Be Displayed" error shows:
HTTP::header insert HttpsIndicatorHeader True
So the maintenance page works as long as the second irule is not attached to the VIP. It was suggested that I insert "event HTTP_REQUEST disable" after the HTTP::respond line "and add 'Connection' 'Close' to the maintenance page respond command to ensure the connection closes and further requests (which would bypass irules entirely) aren't seen." I just wanted to run this by some smart people as well as verify my syntax. Is it possible someone could review?
priority 400
HTTP::respond 200 content [ifile get "poolname_MaintenancePage_ifile"] noserver "Content-Type" "text/html" "Cache-Control" "no-cache, must-revalidate" connection close
- Lee_Sutcliffe
Nacreous
You can't add a header after you have issued an HTTP::respond command. This will likely be why you get an error you will need to add a
after you have issued the response tp make sure the header isn't added (if this is indeed what you want to happen)returnI have put the two iRules together as given they are relatively simple, there is no need for them to be separate.
when HTTP_REQUEST { if {[active_members /partition/poolname_pool] < 1 } { HTTP::respond 200 content [ifile get "poolname_MaintenancePage_ifile"] noserver "Content-Type" "text/html" "Cache-Control" "no-cache, must-revalidate" return } HTTP::header insert HttpsIndicatorHeader True }
