Raju_kavad_2973's avatar
Raju_kavad_2973
Apr 10, 2018
LTMs with GTM Module added post upgrade GTM
we had upgrade GTM from 11.6.1 HF2 to 11.6.2, post upgrade below module are active, How to identify those module activated after upgrade.
before upgrade
Active Modules Global Traffic Manager Module (RWEVQJE-IQVPPUD) STP GTM, DNS LB DNS Express Routing Bundle
Post upgrade
Active Modules Global Traffic Manager Module (SKNSRDT-GJMGAMF) STP GTM, DNS LB GTM, DNS LB, MAX GTM Licensed Objects, Unlimited DNS Rate Fallback, Unlimited DNS Licensed Objects, Unlimited GTM Rate Fallback, (UNLIMITED) DNS Rate Limit, Unlimited QPS GTM Rate, Unlimited LTM, Base, 1600 (VPXLAPY-BTYCXZU) APM, Limited LTM, Base IPV6 Gateway Rate Shaping Ram Cache 50 MBPS COMPRESSION Anti-Virus Checks Base Endpoint Security Checks Firewall Checks Network Access Secure Virtual Keyboard APM, Web Application Machine Certificate Checks Protected Workspace DNS Rate Fallback, Unlimited DNS Licensed Objects, Unlimited DNS Rate Limit, Unlimited QPS App Tunnel Remote Desktop Application Acceleration Manager, Core
how to remove unused a module and why those active post upgrade ?
  • Hello,
    I think there is confusion. this is the license part and not the activated modules.
    If you want to check activate module (provisionned) go to System then ressource provisionning.
    Regards
  • Surgeon's avatar
    Surgeon
    Ret. Employee
    What is the actual problem? Are you getting any issue?
