sundogbrew's avatar
sundogbrew
Jun 28, 2017
LTMs in two sights not in snch
I am having trouble keeping my F5s in sync they are in two locations but have dedicated fiber connections between them for HA. Do I need to change the time interval for poling? Is there a cli command that I can tell what the connection is at? I think it should be 10Gig but not sure how to check. Also would like to see if I am seeing drops, errors...
Thanks Joe
  • Usually, any problems with connectivity and synchronization will show up as error messages in the /var/log/ltm. That should be a good start. K16049 could be of help in your case.
