Akhtar_109015's avatar
Akhtar_109015
Sep 02, 2012
LTM STP compatibility with Cisco Switch
Hello all,
We have connected a single LTM with dual links to 2 different Cisco Catalyst switches using 802.1Q trunks. LTM is configured with RSTP mode and on Cisco Switch RPVST+ is configured.
STP root bridge is hardcoded on the Cisco side.
On F5 STP link type is Auto, STP Edge port is disabled since that port is connected to the cisco switch.
When we are failing over the F5 primary link to the secondary link we see 'Loop Inconsistent' on the cisco switch and things dont work after the failover.
We have tried configuring the F5 as STP passthrough but that doesn't fix out the issue.
I have checked out the forums and found out following recommendations
1. Configuring MSTP bw F5 and Cisco for better compatibility (Not possible from Cisco side because of a major change in large production setup)
2. Configuring VSS in Cisco switches (not possible due to hardware limitation)
3. Connecting F5 using single links to each switch (redundancy compromised)
I am wondering that on which default vlan does the F5 STP instance0 sends the STP BPDUs ? the term used on Cisco side is native vlan and others use PVIDs; that F5 default vlan should match the native vlan on cisco trunk side.
Any suggestions are highly appreciated.
Akhtar
