Wangzixuan_3147's avatar
Wangzixuan_3147
Jun 22, 2018
LTM monitor and least connection
I have A pool, which USES the load balancing algorithm of the least connections. When member A goes down, the connections on member A will be released gradually. At this point, the health check has not reached the timeout, and the state of member A is still up. According to the load balancing algorithm, will there be many connections distributed to member A? If so, is it reasonable?
  • As long as the load balancer sees the pool member as up (i.e., monitor timeout has not occurred), it will keep sending connections to the pool member.
