Connection Monitor
Problem this snippet solves:
Store headers for all requests/responses sent through an application and you can view them from the BIGIP.
How to use this snippet:
Connection Monitor
Requires: client ssl profile, http profile, tcp profile.
- Define the application name. Update "changeme" in CLIENT_ACCEPTED. Must be unique. No spaces.
- Assign to application virtual server.
Connection Tracker
Requires: http profile, tcp profile
Optional: client ssl profile
- Create http virtual server on same BIGIP
- Assign the connection tracker iRule
- Navigate to default page
- Select the application name you defined above
Code :
70949
Tested this on version:
11.6
Updated Aug 16, 2022
Version 2.0Kevin_Davies_40
Nacreous
Joined April 22, 2010
Kevin_Davies
Nacreous
Joined May 17, 2019
