LTM management access issue...
i want to access big IP f5 ltm with non management interface ?
Thanks in Advance...
You'll need to configure port lockdown on the self ip from which you want to manage the box:
https://support.f5.com/kb/en-us/solutions/public/13000/200/sol13250.html
- Shiraz
Altostratus
Absolutely Abdulmoheed,
You can always have access to the F5 device for both GUI and CLI from the self-IP address of the device. However, you need to make sure that the port lockdown on that IP address is not set to NONE. and if you using custom ports, make sure you have https and ssh allowed.
The Article provided by Amine Kadimi explains you everything required.
Regards, Mohammed Mukram
