LTM HTTP/S Monitor for Citrix Access Gateway
LTM version 10.2.1 / Citrix Access Gateway version 5.0.4
I have a customer who is using LTM to load-balance a pair of Citrix Access Gateways. Up until now, they have been using TCP checks (80 and 443) but a recent issue is causing the CAGs web-service to be unavailable while still listening on both ports.
In an attempt to add more specific content to the Send/Receive strings, it has been discovered that ANY use of the "GET" command causes the monitor to fail...even a simple "GET / " with nothing in the Receive string. The only way the monitors work is if absolutely nothing is in either field.
curl results show content being received:
* SSL certificate verify ok.
> GET / HTTP/1.1
> User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
> Host: remote.customer.com
> Accept: */*
< HTTP/1.1 302 Found
< Server: Cyms-SecS v3.0
< Content-Type: text/plain; charset=utf-8
< Content-Length: 37
< Date: Wed, 24 Jul 2013 18:57:56 GMT
< Location: https://remote.customer.com/lp/Remote
< Connection: Keep-Alive
You will be redirected to Login page
* Connection 0 to host remote.customer.com left intact
* Closing connection 0
* SSLv3, TLS alert, Client hello (1):
All I'm looking for in the receive string is the 302 code - but it's not working. So, my question is has anyone else deployed CAG behind LTM and run into a similar issue with custom monitors?
Thanks,
Les
- nitass
Employee
it has been discovered that ANY use of the "GET" command causes the monitor to fail...even a simple "GET / " with nothing in the Receive string. have you tried full send string?
e.g.
GET / HTTP/1.1\r\nUser-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5\r\nHost: remote.customer.com\r\nAccept: */*\r\nConnection: Close\r\n\r\n
sol2167: Constructing HTTP requests for use with the HTTP or HTTPS application health monitor
http://support.f5.com/kb/en-us/solutions/public/2000/100/sol2167.html
