LTM and GTM device certificates
I'm running 11.4.1 and looking to go to 11.6 and currently I have device certificate of 1024.
I know 11.6 is standard 2048 and believe although not recommends 1024 will still work, but with that said I want to update to device certificate key of 2048.
Its seems straight to create a new device certificate and key on a device but whats not clear to me is impact and approach as I have 2 DCs each with 2 ltms active and standby and a gtm in each dc that talks to all ltms these are standalone but in a sync group that allows the config to sync.
what do I update first, ltm or gtm. is there an impact. does the certificate automatically update across or do I manually copy.
any advise would be great
- Domai
Altostratus
When you add ltm's to gtm by using "bigip_add" and "gtm_add" commands it uses 22, 443 to exchange the certs and only then iQuery would start working on port 4353. The certs are copied on to GTM under "trusted certs". I think you need to update LTM's first and restore the device trust between them. Once you validate the ltm's are back to normal, you would see the iQuery calls from the GTM failing. Quickly copy the certs on to gtm is what I think would be the way to go. Yes there would be impact with the above method. Your GTM's will stop responding to the requests because they will not be able to query the status of the ltm's and their vip's.
