Low-CPU way to insert CorrelationID
We would like to implement a correlationID HTTP header for every HTTP message that comes through the frontend VLAN.
i.e. it's going to need to inspect every single HTTP and
- if there is a CorrelationID then ignore
- if there is not a CorrelationID
- generate one
- add it to the header
Obviously the easy way is to just slap an irule on each VIP, but i'm concerned about the CPU cost here. I've seen on the F5 forums ways to measure the time cost... do you know how to extrapolate this to millions of hits? is it likely to be linear?
Is there functionality for this stuff lower level in the LB processing stack? Asic maybe?
- Dario_Garrido
Noctilucent
Hello rogerwow
Depending on your application, you could use cookie persistence to generate a random number for each query, which is less cost intensive.
REF - https://support.f5.com/csp/article/K83419154
Other option is to implement an iRule. Below is one idea.
when HTTP_REQUEST { if { !([HTTP::header exists "X-Correlation-ID"])} { HTTP::header insert "X-Correlation-ID" [string range [AES::key 256] 8 end] } }Other interesting topics to generate unique identifiers.
REF - https://devcentral.f5.com/questions/how-to-generate-visitor-id-uuid
REF - https://devcentral.f5.com/questions/How-random-is-rand-790690
To evaluate the cpu cost you should try it first in pre-production.
show ltm rule IRULE_NAMEKR, Dario.
