morgan
Oct 07, 2020logs prefix (LTM, AUDIT) does not match
Hello,
I have a problem with the local logs on my bigip, indeed the audit logs have the full name of the equipment (host.local) but in my LTM logs I only have the short name (host). This created an edge effect on my log concentrator. I don't know how modify the prefix sent in the logs, can you guide me on the subject? Thanks in advance.
Cdlt.
If you want all logs sent to your remote logging destination to be FQDN (mylab.local) you can try modifying syslog as follow:
# tmsh modify sys syslog include "options {use_fqdn(yes); keep_hostname(no); };"
