JCMATTOS_41723's avatar
JCMATTOS_41723
Feb 21, 2008
Logging Monitor Probe failures?
We have dual 8400 LTM's 9.4.3 and are currently logging to a remote server. However, we would like to also log when a monitor fails the first time initially. Currently, we fail the members after 3 consecutive probe failures and would like to be notified upon the initial probe failure. Please advise!
syslog {
messages from notice
messages to emerg
remote server 172.x.x.x
So far in the logs all we get is this:
Thu Feb 21 13:29:04 PST 2008
F5-DC-LB1
mcpd[16451]
01070640
Node 10.0.x.x monitor status down.
  • hoolio's avatar
    hoolio
    I don't know of a way to do this. By default, I don't think anything is logged when an individual monitor request fails. It's only when no valid response is received over the period of the timeout that the member is marked down and a log entry is generated.
    If you wanted to check for client traffic failing, you could add a rule which logs a custom entry from LB_FAILED and configure a custom syslog alert based on the log string. Not sure if this is helps you though.
    Aaron
  • DB's avatar
    DB
    Is there a way to log "which" monitor failed when one of multiple monitors on a pool member fails? I have nodes in a pool which have two health monitors and in the pool an Availability Requirement of "ALL" monitors, however all I see in the LTM log is "Pool member 1.2.3.4:80 monitor status down." I cannot tell which of the two monitors failed, assumuing it's only one of them, to know which app specific monitor I should be diagnosing.
  • hoolio's avatar
    hoolio
    Sure. You can enable a database key to instruct bigd to print the monitor name which failed when a pool member is marked down by running 'b db bigd.lognodestatuschange enable' from the command line. See this post for details:
    Email notification of node/vs down
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=31&tpage=2&view=topic&postid=2016728526
    Also, you can enable debug on the monitoring daemon, bigd, by running 'b db bigd.debug enable' at the command line. The output is written to /var/log/bigdlog. The logging is very verbose so disable the logging once you're done collecting logs (using 'b db bigd.debug disable').
    Aaron
  • You can enable bigd debugging, enter at the cli:
    Messages are in /var/log/bigdlog.
  • DB's avatar
    DB
    Thanks folks. I've turned on the lognodestatuschange and it's giving me exactly what I need. I already have a few bites on it!
