Robert_Sutcliff's avatar
Robert_Sutcliff
Jun 05, 2008
logging and redirects
We're having problems setting up logging (similar to apache http access logs). We need to log all the relevant data onto one line, so that we don't get data from lots of concurrent requests mixed up.
To generate the one line access log - some data has to come from HTTP_REQUEST, and some from HTTP_REPONSE event - I'm using the code below.
 set date_time_request [clock format [clock seconds] -format {%Y-%m-%d %H:%M:%S %z} ]
 set cs_ip [IP::client_addr]
 set cs_host [HTTP::host]
 set cs_vhost [virtual]
 set cs_uri [HTTP::uri]
 set cs_method [HTTP::method]
 set cs_bytes [HTTP::header Content-Length]
 when HTTP_RESPONSE {
 set sc_status [HTTP::status]
 set sc_bytes [HTTP::header Content-Length]
 when CLIENT_CLOSED {
 what vars are there
 log local0. "[info vars]"
 do we have any variables? if not exit to prevent errors
 if { not [info exists date_time_request] } { return }
 set log_str "$cs_vhost $cs_host $cs_ip - \[$date_time_request\] \"$cs_method $cs_uri\" $sc_status $sc_bytes [IP::remote_addr]"
 write to syslog
 log local0. $log_str
The problem is that in other iRules we use the HTTP::respond or HTTP::redirect functions.
When using either of these statements we get no log at all!
These functions appear to cause the HTTP_RESPONSE event to not be evaluated. For this reason I moved the actual logging statement to CLIENT_CLOSED (which is still evaluated), and was willing to see just a couple of missing fields.
However I soon found that when the HTTP::respond and HTTP::redirect functions run they also appear to drop the entire TCL variable stack (for this connection).
Has anyone see a similar problem, or know of a fix or work-around?
Cheers,
Rob
  • hoolio's avatar
    hoolio
    I don't think there is a way to determine that HTTP::redirect or HTTP::respond have been used to respond to an HTTP request. You could set a variable in the redirect rule(s) and then look for that in the logging rule. You could use priority to dictate that the HTTP_REQUEST event in the log rule runs after the default priority of 500 (when HTTP_REQUEST priority 501). You could then log the request/response details in HTTP_REQUEST if the request is being redirected by another rule. You'd also want to make sure to unset the variable (or set the value to 0) if the request isn't being responded to from the rule, so the variable will be valid for all HTTP requests on the same TCP connection.
    Also, someone mentioned previously that it's more efficient to save the log items in a single variable compared with using half a dozen:
     when HTTP_REQUEST priority 501 {
         Check if another rule on this request has issued a response
        if {[info exists redirected] && $redirected]}{
            Log the request details now, as there won't be a server response
           log local0. "[virtual] [HTTP::host] [IP::client_addr] - \[[clock format [clock seconds] -format {%Y-%m-%d %H:%M:%S %z}]\] \"[HTTP::method] [HTTP::uri]\" - -"
        } else }{
            Request isn't being answered from the BIG-IP so save the request details for logging in HTTP_RESPONSE
           set request_info "[virtual] [HTTP::host] [IP::client_addr] - \[[clock format [clock seconds] -format {%Y-%m-%d %H:%M:%S %z}]\] \"[HTTP::method] [HTTP::uri]\" ..."
         Response received from the pool.  Log the request + response details
        log local0. "$request_info + some response details"
     when LB_FAILED {
         Load balancing the request failed, so log the request details here?
        log local0. "$request_info - something indicating no server response?"
    Here is an example rule which could redirect the client and set a variable to track the redirection.
         Check if some condition is true
        if {$some_condition == 1}{
            Track that the client is being redirected
           set redirected 1
            Redirect the client
           HTTP::redirect https://example.com
            Track that the client is not being redirected
           set redirected 0
    Aaron
