storg_88340
May 08, 2008LocalLB.Pool.get_member() call using perl
I've just started using perl to query our F5, and what I've done so far (not much) is working,
but it seems I must be doing things the hard way.
I've done this
$jjjj = 'pool_test';
$soapResponse = $Pool->get_member(SOAP::Data->name(pool_names => [ ($jjjj) ]) );
&checkResponse($soapResponse);
@blah = @{$soapResponse->result};
which works, and I get a array of arrays of hashes, with address and port of my pool members,
but the resultant thingie that is returned by the get_member() call appears to be an object,
I used data dumper on it.
print Dumper( @blah );
and this is what comes out
$VAR1 = bless( [
bless( {
'address' => '1.1.1.2',
'port' => '100'
}, 'Common::IPPortDefinition' ),
bless( {
'port' => '101'
], 'Common::IPPortDefinition[]' );
So what's the most correct/neatest way of getting my address and port out of that structure.
I've printed the values doing this
foreach $xx ( @blah ) {
foreach $yy ( @{$xx} ) {
foreach $key (keys %{ $yy } ) {
print "Key:$key Data: ${$yy}{$key}\n";
and it gives
Key:address Data: 1.1.1.2
Key:port Data: 100
Key:port Data: 101
Seems a little unwieldy
Mark.
- The get_member() method returns a 2-d array. The first dimension to match to each pool name you passed in in the pool_list parameter. The "Disabling Node Servers" codeshare entry will query all pools, and then pass that list into get_member, and then enumerate through the 2-d array.
http://devcentral.f5.com/wiki/default.aspx/iControl/DisablingNodeServers.html
Click here
Look for the findPoolsFromMember() method. It calls a subroutine to get the 2-d array of members and loops through the results. Not sure if this is the "best" way, but it does work.
Cheers!
-Joe
