Muhammad_Ausaf_'s avatar
Muhammad_Ausaf_
Mar 12, 2019
Load Balancing within the same VLAN
Dear All;
Can we do Load Balancing within the same VLAN using the f5 appliance and how?
  • Hi
    I am not sure to understand your issue... Load balancing is defined at the pool level, so as long as pool members are reachable by the BigIP (appear green in the pool object) there should be no issue to load balance between them.
    Same VLAN or not, it's the reachability of pool member that is key.
    Yoann
