Murali_Thutera_'s avatar
Murali_Thutera_
Aug 30, 2010
Load Balancing with Source/Destination Adrress Affinity
We are using skelta application to connect to the webservice and try to upload the files but the client(skelta application, its a thick client) is not understanding the cookie. We want to do a load balance as well as use the persistence connection. How do i acieve this.
I have tried with source and destination address affinity but the load balancing is not happening. All the connections are hitting to the only one server in the pool. The clients which are connecting will be from same subnet.
Any help in this is appreciated.
Regards
Murali
