Load-balancing traffic to servers into a VLAN and Subnet not linked to the F5
Hello
I'd like to know if it is possible to create and send trafic to servers that are not into in VLAN defined in the F5 BIG-IP, to put them into a POOL and defined this pool in a VS with SNAT or AUTOMAP configured.
for example : Vlan A : VS defined on that vlan with ip1 vlan A : Floating ip has ip2 (use aslo for snat automap) Vlan A : a router as gateway for that subnet
Vlan B : some nodes X and Y into that vlan (IPx and IPy) This vlan is not define into the F5 ; configured somewhere else, routed by a gateway ; routing is OK between F5 and Servers
The trafic should be sent to the server with : IP source (ip2 from vlan A) and Dest IP : IPx using the gateway router as node X is outside the vlan Then , Node will answer with Source IP : IPx and Dest IP : ip2 which is the SNAT address
Does it works ? or Do servers nodes must be into a VLAN attached to the F5
- Vijay_E
Cirrus
Server nodes don't have to be in VLAN directly attached to the F5. SNAT may be required depending on the Network setup and GW configured on the servers.
- Arnaud_Lemaire
Employee
Hello Jacques, you can have routed pool members. BIG-IP will use his routing table to reach them. all you need to check is that servers have a route back to the BIG-IP SNAT address, or if you don't SNAT some PBR redirecting traffic to BIG-IP to keep sessions coherent, otherwise that another type of configuration using asymetric proxy on BIG-IP.
