ALAIN_CHASTAGNE's avatar
ALAIN_CHASTAGNE
20 years ago
Load balancing of RADIUS
Does anybody know how to load balance radius authentication incoming flow from N clients to M servers through BIG-IP ? we thought of using the "User_Name" information element to set a persistency on the radius authentication session, is it possible to parse it using i-rules ? other solutions ?
Thanks for tips
  • Tao_Liu_90341's avatar
    Tao_Liu_90341
    Historic F5 Account
    There are two options.
    1. persist on source address, no irule is required.
    2. write rule to parse Radius/UDP packets, after extracting desired option, do uie persistence. datagram_lb must be enabled in udp profile.
