Load balancing not working
I have 2 Real servers and I am using default source address persistence. As one my real server goes down, the connection does not move to other load balancer. Where could b the issue?
- PeteWhite
Employee
If you have an active session then LTM will try to send the traffic to the previous server, as per persistence. When the backend server goes down then the LTM will reset the connection.
However, you can change this behaviour with the pool setting "Action on Service Down" - change this to Reselect and it will try to send the connection to a new node once the previous one goes down.
- Vitaliy_Savrans
Nacreous
Did your configure connection and persistance mirroring? SOL13478
- AnuragMishra_13
Hi Pete, thanks. I Changed "Action on Service Down" to reselect and it worked.
