Load Balancing Microsoft's Web Application Proxy Servers
I am working on a project with Exchange 2013 and we are attempting to put it behind the load balancers currently running to 10.2.3. Most of the components have worked fairly straight forward but I am having issues with the Web Application Proxy servers on the front end public facing. Our security team required some additional logging of Client IP and User name so I have an IRule for that piece the challenge seems to occur after I implement SSL Bridging and terminate the SSL and attempt to put an HTTP Profile on for the IRule it breaks the connect. Anyone else out there Load Balancing this application currently have any recommendations?
- Pratik_125797
Can you share copy of your irule.
- Mahmoud_Eldeeb_
the best way to deploy exchange 2013 with ltm is to have 11.6.0 as a ltm software version and to use exchange 2013 iAPP template
