A__N_5261
Jan 11, 2012Load Balancing is not working
HI ALL,
We have pool with four member. All member are up and pool configure with Health moniter.
they have running webpage on member when we surf that webpage . That machine name come up.
when refersh from my maching it show only one maching or some time other machine name.
I tried from different Browser that same time and different maching.
First i configure Round Robin Load balance does not happen . I tried observer not happened.
I see only 2 server name when i referesh.
Please any body can tell what can be issue. from LB HOW we can check . for particual Pool Load balancing is happeneing or not
Client want full load balance
Thanks & Regards
Ankush Narang
- nitass
Employee
have you ever tried to close and re-open browser or use ctrl+f5 instead of refresh?
normally bigip does load balancing only one for each tcp connection. - A__N_5261
i tried other broswser and closed also
is there any way to check from LB side. its getting load balance or not
Ankush - nitass
Employee
is there any way to check from LB side. its getting load balance or notmay you check statistics page? it is at overview > statistics > local traffic and then select pools on statistics type. - A__N_5261
Thanks for instant Reply Nitass
But statistic show only
in/out bits and packet and
current connection
maximum connection
toal request
it does not show how many request handel by which memeber. Is ther any other way
Thanks & Regars
Ankush Narang - nitass
Employee
it does not show how many request handel by which memeber. Is ther any other way have you selected pools as statistics type? - A__N_5261
yes.. I can see. i think i missed last time. Thanks - hoolio
SOL10430 might also offer insight for this:
sol10430: Causes of uneven traffic distribution across BIG-IP pool members
http://support.f5.com/kb/en-us/solutions/public/10000/400/sol10430.html
Aaron
