Load balancing for sticky persistence
how to make load balancing in two web server if the virtual server using sticky destination-address? if must to need Irule, please give me example to create.
Thanks for your answer/help Martin
- Vitaliy_Savrans
Nacreous
May it will be better to change type of persistance?
- Kevin_Davies_40
Nacreous
See destination persistence
https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-concepts-11-4-0/10.html
Essentially it is designed for web caches. It load balances between the servers based on destination IP address in order to optimise the caching on each device.
If that load balancing is not suitable then you should change it to one that is.
