Eray_27463
18 years agoLoad Balancing Concepts
I want to understand load balancer terminology better, for example I don't quite get the following terms;
selfip, node,pool, load balancing pool, virtualserver,virtualnode, node, pool member, VLAN
Is there a good document that explains these?( Other than SDK documentation)
An example or something graphical that would contain most of these terms would help a lot.
- Andy_Herrman_22
Check out the docs here:
https://tech.f5.com/home/bigip-next/manuals/
I believe the Configuration Guide is the one you'll want. It has chapters on each of those objects/terms.
