Spidey_29396
Aug 18, 2016Load balancing bluecoat proxy. Is it possible?
Hi All,
Is it possible to load balance bluecoat proxies? If yes, what will be the virtual server configurations looks like?
- jgranieri
its a very generic request are you simply asking if you have a virtual server configured as 0.0.0.0:443 & 0.0.00:80 and have a Performance L4 or Standard VS with a Pool of Bluecoat proxy members then yes you can do that in the simplest terms. is that what yo are after?
traffic must use the F5 as a gateway in order for the F5 to Load balance traffic to a pool of proxies.
