Richard__Harlan's avatar
Richard__Harlan
Historic F5 Account
Jun 13, 2005
Load Balancing based on Port
Is there a was in iRules to send traffic to a Pool based on port that the client is sending trafic to. I know you can do IP::addr is there a IP::Port? Thanks
  • Sure, there's a way but it's not in the "IP" namespace. Think of IP as the base class and TCP and UDP are classes derived from IP.
    In the "IP" namespace you can access the addresses
    IP::remote_addr, IP::local_addr, IP::client_addr, IP::server_addr
    And from TCP and UDP you can access the ports with these values
    TCP::remote_port, TCP::local_port, TCP::client_port, TCP::server_port
    UDP::remote_port, UDP::local_port, UDP::client_port, UDP::server_port
    The "server_port" values are only valid when withing the serverside context (server response). If you want to load balance based on the destinaion port of the service (ie, using a wildcard virtual server), use the "local_port". If you want to load balance based on the client's source port (not sure why you'd want to do this), you could with the "client_port" value.
    Also, if you are using a HTTP profile, you can access the port in the HTTP request with the HTTP::port value.
    This reminds me that I need to get back on finalizing the documentation for my iRules cheat sheet...
    -Joe
  • I've considered using TCP::client_port for persisting where all my clients hit an SSL VPN device and come out sharing a single IP address.
  • drteeth_127330's avatar
    drteeth_127330
    Historic F5 Account
    That's probably not a good idea. Session persistence means that separate connections that are part of the same session will be directed to the same back-end server. The problem with the client port is that it generally changes for each client connection. The best way to support session persistence is to use something in the higher-level protocol, like an HTTP cookie. For SSL, one can use the SSL session id for persistence. However, there are problems with tracking the session id across renegotiations.
