Hardik_Mehta_32's avatar
Hardik_Mehta_32
Jan 29, 2018
LOAD BALANCING AND AUTHENTICATING AD
We want to load balance our both AD Servers using LTM,we created virtual servers related to it,but we also want that authentication should be done by LTM i.e. whenever user try to login in domain,request should go to virtual IP and then LTM should authenticate it with backend AD servers
Please help us regarding the same and Thanks in advance
    • Hardik_Mehta_32's avatar
      Hardik_Mehta_32
      Hi eben, Thanks for the reply,Is there any reference or guide you can provide,because I tried searching,all I got was related VPN
      Hardik_Mehta_32
      Hi eben, In above scenario we have created external login page which is used when we want to securely access any application or VPN,in our scenario what we want is when my local users in network login to their PC through domain then LTM should validate its username and password with AD present in backend and also load balance each requests to both individual members.
  • eben's avatar
    eben
    Hi Hardik
    LTM + APM is the solution.
    Regards.
      Hardik_Mehta_32
      Hardik_Mehta_32
