Least Connection problem
We are doing a
LTM demo on customer site for terminal servers. Clients are connected with rdp
We have tried
ratio and obseved. But we can get most equal distribution with least method.
But 2 days later
we have seen that distribution of connection numbers is degraded like attached
files.
srcrpd
persistancy is applied.
Is there a way to
correct
this distribution or acceptable
explanation to customer?
Thanks for your
further helps...
- hoolio
Hi Mustafa,
I'd open a case with F5 Support on this as I think there may be an issue with RDP and least connections.
Aaron - Mustafa_Y__252_
Hi Aaron,
Could you inform us updates or a solution please?
Also is there any other geek who has any idea or a solution?
Thank you for your reply,
