Pedro_Minas's avatar
Pedro_Minas
Jan 19, 2011
LDAP Load Balancing Performance Problem
Hi guys...
I'm having a problem with an vitrual service load balancing LDAP requests... When i request directly to the servers the response is very fast but when i request via BIG-IP the responses are quite slow...
Any opinions?
Virtual Service Config...
service port: 389
protocol profile client: tcp
protocol profile server: tcp
address translation: enabled
port translation: enabled
no persistence
pool with two servers
Thanks in advance...
  • hoolio's avatar
    hoolio
    You could capture tcpdumps of the slow query times through the virtual server and compare that with traces direct to the pool member. You could also try changing to a Performance L4 virtual server with a FastL4 profile.
    Aaron
  • Problem solved... It was the reverse lookup DNS regarding the virtual service IP... There was no entry for the IP in question...
