LDAP authentication of users for GUI
Hi all,
I'm am trying to configure LDAP authentication for our Administrators to access the F5 GUI on our second pair of production F5's.
Some time ago I successfully configured it on our original F5's (prod & test), but for some reason our latest ones just wont take it.
The configurations (all I can find in bigip.conf) are identical for authentication, so I'm a little confused as to why they wont work.
Could someone give me a couple of ideas of why this might be happening?
Many thanks Anthony
- Cory_50405
Noctilucent
Have you tried running a tcpdump on your BIG-IP to verify if communications to your LDAP server are working?
tcpdump -nni 0.0 port 389 and host ldapserverIPaddress
ideas:
as cory suggests, communication (are your new big-ips in a different network, do they need a management route to reach the ldap server)
other version of tmos (so different config)
bit obvious, but does copy pasting the password work out? perhaps try to reconfigure it via the GUI?
- Anthony
I hadn't tried that, but having done so, this is the output (I have replaced IP addresses for security):
[root@LB1:Active:Changes Pending] config tcpdump -nni 0.0 port 389 and host tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 96 bytes 14:53:12.215807 IP .56539 > .389: S 2280840514:2280840514(0) win 14600 14:53:12.216374 IP .389 > .56539: S 2623792533:2623792533(0) ack 2280840515 win 49248 14:53:12.217106 IP .56539 > .389: . ack 1 win 115 14:53:12.217297 IP .56539 > .389: P 1:70(69) ack 1 win 115 14:53:12.217648 IP .389 > .56539: . ack 70 win 49179 14:53:12.231806 IP .389 > .56539: P 1:15(14) ack 70 win 49248 14:53:12.232093 IP .56539 > .389: . ack 15 win 115 14:53:12.232477 IP .56539 > .389: P 70:135(65) ack 15 win 115 14:53:12.232753 IP .389 > .56539: . ack 135 win 49248 14:53:12.234563 IP .389 > .56539: P 15:500(485) ack 135 win 49248 14:53:12.235802 IP .389 > .56539: P 500:1035(535) ack 135 win 49248 14:53:12.235870 IP .389 > .56539: P 1035:1049(14) ack 135 win 49248 14:53:12.236099 IP .56539 > .389: . ack 1035 win 131 14:53:12.237373 IP .56539 > .389: P 135:204(69) ack 1049 win 131 14:53:12.243468 IP .389 > .56539: P 1049:1063(14) ack 204 win 49248 14:53:12.244275 IP .56539 > .389: P 204:273(69) ack 1063 win 131 14:53:12.246356 IP .389 > .56539: P 1063:1077(14) ack 273 win 49248 14:53:12.247753 IP .56539 > .389: P 273:389(116) ack 1077 win 131 14:53:12.248710 IP .389 > .56539: P 1077:1091(14) ack 389 win 49248 14:53:12.257520 IP .56539 > .389: P 389:396(7) ack 1091 win 131 14:53:12.257595 IP .56539 > .389: F 396:396(0) ack 1091 win 131 14:53:12.258015 IP .389 > .56539: . ack 397 win 49248 14:53:12.258775 IP .389 > .56539: F 1091:1091(0) ack 397 win 49248 14:53:12.259140 IP .56539 > .389: . ack 1092 win 131 - Cory_50405
Noctilucent
So the communications look good. As Boneyard says, can you verify the password?
Might be worth capturing this to a .pcap file and viewing in Wireshark to see if that yields more information:
tcpdump -nni 0.0 port 389 and host serverip -s 1500 -w /var/tmp/ldapauth.pcap
Also, can the LDAP server admin give you any information from the server logs?
- Anthony
I've had a look with the guys who look after the LDAP servers and everything looks ok from there.
The traffic is coming from the external vlan self IP. Should this be something else? Is this because of the default gateway? Does a management route need setting up for this traffic? The other F5s haven't got this multiple VLAN configuration yet.
- Kevin_Stewart
Employee
If I may add, it looks like your getting LDAP traffic back and forth, so I doubt there's a networking issue. As Boneyard suggested, using the -Xs0 option in the tcpdump can shed some light on the LDAP itself. The very best tool though, in my opinion, is a WireShark capture. It'll break open the LDAP packets and show you exactly what each side is saying and should pinpoint exactly where the problem is.
- Anthony
Ok so I've run tcpdump -nni 0.0 -s0 -X port 389 and host and in the output I can see all my credentials being returned from the LDAP server.
- Cory_50405
Noctilucent
I know you said all of the configurations were the same, but can you verify the remote role configs to ensure they match? If your BIG-IP is getting the results from the AD server as expected and still not granting access, then it is most likely a configuration issue on the BIG-IP.
- Anthony
Cory, I can confirm that the configs are carbon copies of each other.
- Anthony
I added a management-route tonight and it had no effect on anything.
