insert12_38638
Jun 30, 2011LC incoming connections
- insert12_38638
The IP Address column displays the IP address of each Local DNS that has sent a name resolution request for a wide IP for which the Link Controller is responsible , Is there way we can track the Client ( source IP address ) of incoming connections to a specific Wide IP Member ??? either by iRules , cacti or options available on LC ??
any thoughts ???
Thanks - hoolio
You could use an iRule to log this. Or you could check the connection table. See 'b conn help' for details. For examples of logging at high levels, check the HSL wiki pages:
http://devcentral.f5.com/wiki/default.aspx/iRules/hsl
Aaron
