Sarnoth_81568's avatar
Sarnoth_81568
Aug 01, 2008
LB::reselect problem
Let me give you some background before I get in to the problem.
We have a web application that uses session replication. A node can fail in such a way that it always return 5xx error pages. We would like BigIP to route people to the same node as long as it is up, but if it is down (returning 5xx) it should retry their request on the other node.
To accomplish this I worked from the example in the documentation for HTTP::retry. My irule is at the bottom of the post. The problem is that the logs show it selecting the other node for a retry on a 5xx error, but in reality it tries to connect to the same node twice. If anyone has an idea about how I can make this work I would appreciate it very much.
BigIP log message:
Jul 31 15:26:10 tmm tmm[934]: 01220002:6: Rule methcheck_retry_on_error : Sticky to 1573653002.25635.0000
Jul 31 15:26:10 tmm tmm[934]: 01220002:6: Rule methcheck_retry_on_error : Trying node 10.10.204.93:9060
Jul 31 15:26:10 tmm tmm[934]: 01220002:6: Rule methcheck_retry_on_error : 5xx error caught: retry 1 out of 2
Jul 31 15:26:10 tmm tmm[934]: 01220002:6: Rule methcheck_retry_on_error : Removing cookie
Jul 31 15:26:10 tmm tmm[934]: 01220002:6: Rule methcheck_retry_on_error : Trying node 10.10.204.93:9062
It looks like it is trying port 9060 once and port 9062 once, but in reality two requests come in on port 9060 and none come in on 9062. The second request does not have the BIGipServer cookie and has two x-forwarded-for headers as expected.
irule:
when CLIENT_ACCEPTED {
set retries 0
if { $retries >= 1 } {
HTTP::cookie remove "BIGipServermethcheck"
log "Removing cookie"
if { [HTTP::cookie exists "BIGipServermethcheck"] } {
log "Sticky to [HTTP::cookie value "BIGipServermethcheck"]"
set request [HTTP::request]
when LB_SELECTED {
LB::mode rr
LB::reselect
log "Trying node [LB::server addr]:[LB::server port]"
when HTTP_RESPONSE {
if { [HTTP::status] starts_with "5" } {
incr retries
log "5xx error caught: retry $retries out of [active_members [LB::server pool]]"
if { $retries < [active_members [LB::server pool]] } {
HTTP::retry $request
  • Thanks again.
    I put the latest test as an iRule on the virtual server, then changed "Action on service down" to Reselect....
    I went to one server, Stopped Tomcat, and hit "Continue" and got a 503 error in the browser. I hit refresh, and everything continued as it should. I switched to the other server with correct session state, etc. However that 503 should not be seen and I can't assume customers are going to hit refresh. Tried it about 5X and results were the same!!!
    What is a "reverse" health monitor ?
