Srikar's avatar
Srikar
Apr 05, 2021
LB:detach how it works?
Does LB:detach keeps server side connections open for subsequent client requests? Is it similar to Oneconnect profile? Thanks!
  • I don't think that it keeps them in a pool for reuse it just drtaches them like the OneConnect but without the reuse option. You need Oneconnect for that:
    https://support.f5.com/csp/article/K7964
    https://clouddocs.f5.com/api/irules/ONECONNECT__detach.html
