Keep Connection open on redirect
I have a 443 VS that keeps the connections open and reuse them when needed. I have a 80 VS that redirects to 443 but it always closes the connection after each connection. How can I keep the connection open when going to 80 and redirecting to 443? I have a simple redirection iRule
HTTP::respond 301 Location "https://[HTTP::host][HTTP::uri]"
curl -IL https://clients.F5.com
HTTP/1.1 302 Found
Cache-Control: private
Content-Length: 162
Content-Type: text/html; charset=utf-8
X-Frame-Options: SAMEORIGIN
Strict-Transport-Security: max-age=31536000
Set-Cookie: F5Sess=srjdlx4kzsu3jgodl4vnxmim; path=/; secure; HttpOnly
X-Powered-By: ASP.NET
SERVER:
Date: Tue, 20 Sep 2016 19:13:13 GMT
HTTP/1.1 301 Moved Permanently
Content-Length: 165
Location: https://login.F5.com/en-us/login/Default.aspx
Set-Cookie: F5Sess=me5sjh4v4mdnobkbnx24iryy; path=/; secure; HttpOnly
SERVER:
HTTP/1.1 200 OK
Content-Length: 49534
X-Frame-Options: DENY
Set-Cookie: F5LoginSess=; expires=Mon, 19-Sep-2016 19:13:14 GMT; path=/; secure; HttpOnly
Set-Cookie: ASP.NET_SessionId=; expires=Mon, 19-Sep-2016 19:13:14 GMT; path=/; secure; HttpOnly
Set-Cookie: F5Sess=; expires=Mon, 19-Sep-2016 19:13:14 GMT; path=/; secure; HttpOnly
Set-Cookie: F5ConnSess=; expires=Mon, 19-Sep-2016 19:13:14 GMT; path=/; secure; HttpOnly Date: Tue, 20 Sep 2016 19:13:13 GMT
curl -IL clients.F5.com
HTTP/1.0 301 Moved Permanently
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
HTTP/1.1 302 Found
Content-Length: 162
Set-Cookie: F5Sess=qc0yfggejzly1lukn5daw2qg; path=/; secure; HttpOnly
SERVER:
Date: Tue, 20 Sep 2016 19:15:25 GMT
Connection: close
Content-Length: 165
Set-Cookie: F5Sess=owdyyxsu4lrzx1ousa4uyspe; path=/; secure; HttpOnly
SERVER:
Connection: close
HTTP/1.1 200 OK
Set-Cookie: F5LoginSess=; expires=Mon, 19-Sep-2016 19:15:25 GMT; path=/; secure; HttpOnly
Set-Cookie: ASP.NET_SessionId=; expires=Mon, 19-Sep-2016 19:15:25 GMT; path=/; secure; HttpOnly
Set-Cookie: F5Sess=; expires=Mon, 19-Sep-2016 19:15:25 GMT; path=/; secure; HttpOnly
Set-Cookie: F5ConnSess=; expires=Mon, 19-Sep-2016 19:15:25 GMT; path=/; secure; HttpOnly
Connection: close
- Vijay_E
Cirrus
Who is sending the TCP connection close FIN flag ? Client or F5 ? You should be able to identify this by doing a tcpdump. I am guessing the client browser is closing the connection once a redirect is received.
- tatmotiv
Why would you want to keep the tcp connection to port 80 open after the redirect? In most cases (if the service is configured properly), there will not be any further http requests to port 80 as the redirection already has happened. All subsequent requests should go to port 443, which of course can only be handled in a separate tcp connection due to the changed destination port.
Hi Rjones,
there is no relationship between the HTTP and HTTP Virtual Servers. You can savely close the connection on HTTP without getting any side effecs for the subsequent HTTPS request.
I guess its just CURL that tricks you out and send slightly different request for
andcurl -IL https://clients.F5.com
.curl -IL clients.F5.comYou could issue a
andcurl -v -IL https://clients.F5.com
to see any differenced in CURLs request headers.curl -v -IL clients.F5.comCheers, Kai
