MOHIT_125417
Altostratus
Jun 15, 2015Issue with ROUDROBIN loadbalancing
Hello Experts,
Recently experienced an issue where on my LBVS roundrobin load balancing method is configured but only one of my real server is handling all the traffic.
Someone having any ided why the round roundrobin algorithm was not working in a way it should be?
- Vitaliy_Savrans
Nacreous
Hello, do you use any type of persistance?
- MOHIT_125417
Altostratus
Persistence is not configured
- MOHIT_125417
Altostratus
Sorry to mention "NO PERSISTENCE" - Pragathishakar1
What is the connection do you see in the statistics in pool that is tagged in with VS? Did you check that any ratio or persistence is enabled? - MOHIT_125417
Altostratus
In the Pool only one Pool Member is serving traffic others are Idle. Presistence is not configured on the Virtual Server. - stan_piron
Cumulonimbus
Did you configure priority group activation in the pool?
Can you post the VS and pool configuration?
