Junaid_Subhani_
Jan 21, 2015Issue with F5 LTM Trial VM
Hi guys,
I am using vCloud to setup a virtual environment for testing.
I have primarily 2 networks, 192.168.2.X AND 142.133.174.X network.
The issue is I am unable to connect both networks to the VM. if the 192 network is connected, the 172 wont connect and vice versa. While one network is connected, the other just goes into promiscuous mode and vice versa.
I really need 2 networks connected to the F5 LTM VM. Any ideas ? I have even trying setting the IP statically but to no avail.
- Brad_Parker
Cirrus
Have you created two defined VLANs and assigned one un-tagged to each interface?
