gsandu_255860's avatar
gsandu_255860
Jul 05, 2016
Issue with BIG-IP Initial Configuration .
I setup LTM according to article https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-system-initial-configuration-11-6-0/1.htmlunique_1616379767 . According to BIG-IP XUI everything looks fine. All Virtual Servers & nodes & pool are green , but can not access to Virtual Server from browser https://10.100.223.200:8443 (VS- pool - 2 nodes). According to netstat output port 8443 is not open . Could you please help to troubleshoot the issue .
tmsh list /ltm
ltm default-node-monitor {
    rule icmp
ltm dns analytics global-settings { }
ltm dns cache global-settings { }
ltm dns nameserver ns93 {
    address 10.100.93.1
    route-domain 0
ltm global-settings connection { }
ltm global-settings general {
    maintenance-mode enabled
    snat-packet-forward enabled
ltm global-settings traffic-control { }
ltm node node01 {
    address 10.100.222.41
    description node01
    logging enabled
    session monitor-enabled
    state up
ltm node node02 {
    address 10.100.222.42
    description node02
    logging enabled
    state up
ltm persistence global-settings { }
ltm persistence source-addr PCOIP {
    app-service none
    defaults-from source_addr
ltm pool http_pool {
    members {
        node01:http {
            state up
        node02:http {
            state up
    monitor gateway_icmp
ltm profile client-ssl RAA-cert-test {
    app-service none
    cert default.crt
    cert-key-chain {
        default {
            cert default.crt
            key default.key
    chain none
    defaults-from clientssl
    inherit-certkeychain true
    key default.key
    passphrase none
ltm profile http XFF {
    app-service none
    defaults-from http
    proxy-type reverse
ltm profile server-ssl ccmqa.com-ssl-test {
    app-service none
    defaults-from serverssl
ltm rule DirectAccess_NLS {
HTTP::respond 200
ltm virtual http_vs02 {
    destination 10.100.223.20:http
    ip-protocol tcp
    mask 255.255.255.255
    pool http_pool
    profiles {
        tcp { }
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 8
ltm virtual https_vs01 {
    destination 10.100.223.15:https
    ip-protocol tcp
    pool http_pool
    profiles {
        RAA-cert-test {
            context clientside
        tcp { }
    source 0.0.0.0/0
        type automap
    vs-index 7
ltm virtual vs03_https {
    destination 10.100.223.200:pcsync-https
    ip-protocol tcp
    persist {
        ssl {
            default yes
    pool http_pool
    profiles {
        RAA-cert-test {
            context clientside
        tcp { }
    source 0.0.0.0/0
        type automap
    vs-index 9
  • Doesn't seem to be anything blindingly obvious in the config you've shared.
    When you say you can't access it - What are you getting ?
    For troubleshooting purposes I would recommend running a TCP dump on the F5 and seeing if TCP level traffic is hitting the vip
    tcpdump -i 0.0 host 10.100.223.200 and port 8443
    • gsandu_255860's avatar
      gsandu_255860
      Thank you for all your assistance . I really appreciate your help in resolving the problem.
  • 10.100.223.200.8443 > 10.100.223.100.42898: Flags [R.], cksum 0xd40f (incorrect -> 0x3414), seq 0, ack 3316455820, win 0, length 0 out slot1/tmm1 lis=
      gsandu_255860
      cksum 0xd40f (incorrect -> 0x3414), - It is similar that the port is closed.
    • IainThomson85_1's avatar
      IainThomson85_1
      Well - That looks like the VIP is resetting the connection. Difficult to tell the exact reason with analysis of the TCPdump in Wireshark. What error do you get on the browser/application ?
  • Odaah , Thank you for all your assistance. I really appreciate your help in resolving the problem. https://support.f5.com/kb/en-us/solutions/public/13000/200/sol13223.html - very helpful.
    [root@f5:Active:Standalone] config  tmsh modify /sys db tm.rstcause.log value enable
    [root@f5:Active:Standalone] config  tmsh modify /sys db tm.rstcause.pkt value enable
    [root@f5:Active:Standalone] config  tmsh show /net rst-cause
    TCP/IP Reset Cause
    RST Cause:                                                  Count
    Maintenance mode (all VIP/SNAT/Proxy connections disabled)      3
    [root@f5:Active:Standalone] config  tmsh modify /ltm global-settings general maintenance-mode disabled
    All is done .
    Thank you again for everything you’ve done.
