PaMBa_173394
Nov 05, 2014Issue in load balancing roun robin algorithm:
Hi Another help =(, I have a pool of 6 members for 3389 service. The load balancing is round robin. All nodes are identical in CPU and RAM. But always one of them have more connections than of others. The ratio for all nodes is 1.
Who could help me please?
- nitass
Employee
is it possible to try disabling cmp for the virtual server? sol14358: Overview of Clustered Multiprocessing (11.3.0 and later) https://support.f5.com/kb/en-us/solutions/public/14000/300/sol14358.html Disable CMP as nitass suggested. This worked for me. But if you are getting multiple requests on one connection then you can edit it in HTTP profile in requests per connection to 1.
- PaMBa_173394
I going to check if works :O, thanks again nitass !!!
