Nikoolayy1's avatar
Aug 02, 2022
Solved
Is there a way for the F5 AFM Protocol Inspection signature match to automatically do pcap capture?
Hello,
Is there a way for the F5 AFM Protocol Inspection signature match to automatically do tcpdump pcap capture and save it to a file? The idea is when a signature is triggered by the IPS to to capture the bad packet if it is a false positive, so it can be reviewed.
  • Hello, As for now in the security logging profile there seems to be a tab called " log packet payload" for the Protocol Inspection logging that should do the job 🙂 The only issue is that the payload that triggered the violation is saved as hex but a converter solves this this issue.
  • As the payload may be large or there would be a large number of logs generated, it would be better to send the logs to a remote logging server.
