Jeremy_Progress
Mar 02, 2016Is there a way for LTM to alert when a node has been out or down for more than 24 hours?
Does F5 LTM have a report or a way to report when a server has been marked down or disabled for more than 24 hours? We have been using the PowerShell Module to pull the data but that is Reactive and are looking for a Proactive way to monitor and be alerted when a node has been down for a given amount of time.
- The_Bhattman
Hi Jeremy_Progressive,
iCALL is a mechanism you can use to help create something like this (https://devcentral.f5.com/wiki/iCall.Homepage.ashx). I have never had to do one but it should work in theory.
I hope this helps
-=Bhattman=-
