is there a place to find a resource's required configuration identifies?
I am getting the following error: one or more configuration identifiers must be provided
I am POST to https://$f5ip/mgmt/tm/ltm/virtual/~Common/
below is the payload i am passing as the body json
"source": "0.0.0.0/0",
"ipProtocol": "tcp",
"description": "autocreated sitename_vs",
"rateLimit": "disabled",
"destination": "VIP:443",
"mask": "255.255.255.0",
"rules": [
"_sys_https_redirect"
"Name": "sitename_vs",
"sourceAddressTranslation": {
"type": "automap"
"pool": "poolname_pool",
"partition": "Common"
I have read through the icontrol rest api user guide, but found little help.
thanks,
- Paula_Livingsto
Altocumulus
Could you post your complete script please?
This one works for me:
POST https://{{bigip_a_mgmt}}/mgmt/tm/ltm/virtualAnd the body:
{ "source": "0.0.0.0/0", "ipProtocol": "tcp", "description": "autocreated sitename_vs", "rateLimit": "disabled", "destination": "10.23.98.222:443", "mask": "255.255.255.255", "rules": [ "_sys_https_redirect" ], "name": "sitename_vs", "sourceAddressTranslation": { "type": "automap" }, "profiles" : [ { "kind" : "ltm:virtual:profile", "name" : "http" }], "pool": "pool_test", "partition": "Common" }I had to correct "Name" to "name", the mask from "255.255.255.0" to "255.255.255.255" and add the http profile. This is needed when using the _sys_https_redirect iRule.
- donfouts_363600
this is the corrected code = after following the answer below,
but i wanted to post this for any other Powershell users out there...
virtual server creation $snap = @{} $snap.Add('type','automap') $snapp = $snap | convertto-json $profile = @{} $profile.add('kind','ltm:virtual:profile') $profile.add('name','http') $profile.add('partition','Common') check to see if vs is already created $uri = "https://$f5ip/mgmt/tm/ltm/virtual/$vs" reset err value $err = $false try{$resp=Invoke-WebRequest -Method Get -Uri $uri -insecure -Headers $headers -Credential $credentials}catch{$err = $_.Exception} if($err.Response.statuscode -match 'NotFound') { write-error 'returned a 4xx, virtual server must not exist' create https vs $URI = "https://$f5ip/mgmt/tm/ltm/virtual" $rules = @("_sys_https_redirect") $body = @{"name"="$vs"; "partition"="Common"; "rateLimit"="disabled"; "ipProtocol"="tcp"; "source"="0.0.0.0/0"; "destination"="${stgvip}:443"; "mask"="255.255.255.255"; "description"="autocreated $vs"; "pool"=$PoolName; "profiles"= @($profile); "sourceAddressTranslation"=$snap} $JSONBody = $body | ConvertTo-Json $newvirtualserver = invoke-webrequest -Method POST -URI "$URI" -Insecure -Body $JSONBody -Headers $headers -Credential $credentials }else{ write-error 'server already exists' }
