is it possible to use different mgmt ip for Tenant and OS ?
If I need to use different subnet for F5OS and Tenant ? I am in the process of building a new tenant but want to use different mgmt subnet from the one which is used for F5OS Mgmt Block.
Note that this is rSeries 4600 hardware.
- Injeyan_Kostas
Nacreous
Hi f5Subrun
This is not possible. You cannot select different mgmt vlan for tenants than F5OS.
- f5Subrun
Cirrus
thank you. Can you advise technicality of it why this is not possible ? Is it something related to shared mgmt Interface logical and physical ?
I don't know why it is is important why it can't be done as like Injeyan_Kostas mentioned it is not possible as this is how it always was with VIPRION or iSeries vCMP and now F5OS. Basically it is not possible because how the system is designed.
