wtwagon_99154's avatar
wtwagon_99154
Feb 17, 2009
Is it possible to monitor for two expressions?
I wanted to see if it was possible to run a health monitor against two expressions.
Example:
GET /index.html HTTP/1.0\r\n\r\n
HTTP/1.0 200
OR
HTTP/1.0 404
Or can you apply two monitors against it -- one looking for HTTP/1.0 200 and one looking for HTTP/1.0 404. If they both fail, the pool member will be determined as down?
  • James_Quinby_46's avatar
    James_Quinby_46
    Historic F5 Account
    I think this is totally possible - you'd want to craft a regular expression that contains both content that will be on the page under normal conditions, and a string that appears when a 404 is displayed. Take a peek at the 2nd post in this thread for an example:
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=32&tpage=1&view=topic&postid=3213232132
