Chris_Scales_10
May 23, 2006irule works on 9.1.0 but not 9.1.1
Hello,
I have an irule that is supposed to verify a client ssl cert connection. When the rule is run on our LTM running 9.1.0, it works fine; if I apply the same rule to the LTM running 9.1.1 it fails. I'm new to F5 and support has pointed me here to look for a solution.
here's the irule:
when RULE_INIT {
set ::key [AES::key 128]
log local0. "the key is: $::key"
when CLIENTSSL_CLIENTCERT {
session add ssl [SSL::sessionid] [X509::verify_cert_error_string [SSL::verify_result]] 180
session add ssl [SSL::sessionid] [SSL::cert 0] 180
if {! [HTTP::cookie exists ClientZ]} {
set id [SSL::sessionid]
set cert [session lookup ssl $id]
if { $cert ne "" } {
log "cert is: $cert"
session delete ssl $id
log "no cert, no connection!"
reject
return
set z [b64encode [AES::encrypt $::key $cert]]
set cert [AES::decrypt $::key [b64decode [HTTP::cookie ClientZ]]]
HTTP::header insert ClientCert [b64encode $cert]
log "Inserting HTTP header ClientCert: $cert"
when HTTP_RESPONSE {
if { [info exists z ]} {
log "in http response Z is: $z"
HTTP::header insert "Set-Cookie ClientZ=$z"
- Colin_Walker_12Historic F5 AccountIt looks like it's possible that your variable "z" isn't getting re-set. Is it trying to insert the cookie twice? Is the "z" variable getting logged as double length?
Colin
