irule with two subsets of sideband connection - one works fine the other failed
Hello forum,
I have an irule that contains 2 subset of of sideband connection procedure, origianlly replaced http authentication which does not work in route domain enviroment (works only in common route domain).
The 1st sideband connection (called sms_session" ) is used to send OTP to end user via sms broker - thats works fine.
The 2nd sideband connection (called enc_id" ) is used for sending encrypted username for autherization service - that's fails.
Both works in route domain 5 in my Viprion configuration.
The error that i get in CLI is as follows:
"Aug 4 19:26:35 slot3/vip_bareket err tmm3[13801]: 01220001:3: TCL error: /REMOTE.KISHURIM/fixed_mnbs_rule - Command must start with connect.invalid connection handle (line 1) invoked from within "connect info -idle -status $conn" ("enc_id" arm line 14) invoked from within "switch -glob [ACCESS::policy agent_id] { "otp" { set otppw [string r...""
Any Idea - why it works for one and not for other.
Regards,
Yossi Mor
- Kevin_Stewart
Employee
Did you close the first sideband channel before opening the next? Otherwise, I don't think your connect string is correct. Can you post the complete iRule?
- Yossi_100623
HI Kevin,
Thanks for your quick response.
Is there a way to attach a file since i get limitation when pasting the irule here.
Regards,
Yossi
- Kevin_Stewart
Employee
Send a private message and I'll send my email address.
- Yossi_100623
I am sorry,
How do i send private message ?
I am new to this forum.
Yossi
- Kevin_Stewart
Employee
Go to your messages Center, click "Compose a New Message", type my user name, subject, your message, and then send.
