harton's avatar
harton
Oct 04, 2013
Irule with elseif and pool selection
Hello,
I'm trying to write an irule that routes traffic to a specific pool based on the host. I think I'm fairly close, but I can't figure out the following error:
01070151:3: Rule [test-pool-selection] error: line 5: [undefined procedure: elseif] [elseif]
   switch -glob [string tolower [HTTP::host]] {
    if { [HTTP::host] starts_with "abc" } {
        pool ss-devsp3-pool
  } elseif { [HTTP::host] starts_with "def" } {
        pool ss-devsp3-pool-81
  } elseif { [HTTP::host] starts_with "ghi" } {
        pool ss-devsp3-pool-82
  • You're using an if/elseif structure inside a switch conditional. Try this:
            "abc*" {
                pool ss-devsp3-pool
            "def*" {
            "ghi*" {
  • The problem you have is you are starting with a switch and confusing the runtime with if statements.
    If you want to use If's, then it would look more like this:
        set hostname [string tolower [HTTP::host]]
        if { $hostname starts_with "abc" } {
            pool ss-devsp3-pool
        } elseif { $hostname starts_with "def" } {
        } elseif { $hostname starts_with "ghi" } {
    Using the switch statement, it would look more like this:
            abc*    {  pool ss-devsp3-pool }
            def*    {  pool ss-devsp3-pool-81 }
            ghi*    {  pool ss-devsp3-pool-82 }
  • harton's avatar
    harton
    Thanks for the help. Let me test these out, and I'll let you know which one worked for me.
  • harton's avatar
    harton
    Thanks again everyone for your help. I ended up using the if statements that Robert gave.
  • Also similar question here what happens if the pool "ss-devsp3-pool" is down, will it reach default pool if configured . And shouldn't switch have a default pool ?? am I wrong in understanding this.
    • nitass's avatar
      nitass
      >what happens if the pool "ss-devsp3-pool" is down, will it reach default pool if configured . no, i do not think so because load balancing is based on host header (not availability of pool).
