Mike_Blue_30573
Feb 04, 2005IRule V4.x to 9.x conversion problem
I have tried over and over to convert this rule to V9. I get an
error saying that "Wrong of args". I am no irules expert obviusly.
I have been trying to walk through the TCL and Irule supplement pdf
but I am still messing something up.
Any help would be greatly appreciated.
if (domain(http_host, 3) == "stage.test.com") {
use pool test_http
else {
if (domain(http_host, 3) == "stage1.test.com") {
use pool test_svra
else {
if (domain(http_host, 3) == "stage2.test.com") {
use pool test_svrb
else {
discard
Freakingenius "ok maybe not with irules".
- Mark_Crosland_1Historic F5 AccountTry the following (I assume http_host was a variable assigned elsewhere?).
if { [domain $http_host 3] == "stage.test.com" } { use pool test_http } else { if { [domain $http_host 3] == "stage1.test.com" } { use pool test_svra } else { if { [domain $http_host 3] == "stage2.test.com" } { use pool test_svrb } else { discard } } } - rapmaster_c_127Historic F5 AccountPosted By gus on 2/4/2005 10:09:10 AM
Try the following (I assume http_host was a variable assigned elsewhere?).if { [domain $http_host 3] == "stage.test.com" } { use pool test_http } else { if { [domain $http_host 3] == "stage1.test.com" } { use pool test_svra } else { if { [domain $http_host 3] == "stage2.test.com" } { use pool test_svrb } else { discard } } }
(Or if http_host was not a variable assigned somewhere, use
instead.)[HTTP::host] - unRuleY_95363Historic F5 AccountCleaned up a little it would look like this:
when HTTP_REQUEST { if { [domain [HTTP::host] 3] eq "stage.test.com" } { pool test_http } elseif { [domain [HTTP::host] 3] eq "stage1.test.com" } { pool test_svra } elseif { [domain [HTTP::host] 3] eq "stage2.test.com" } { pool test_svrb } else { discard } }
Or using a Tcl switch statement you could do:when HTTP_REQUEST { switch [domain [HTTP::host] 3] { stage.test.com { pool test_http } stage1.test.com { pool test_svra } stage2.test.com { pool test_svrb } default { discard } } } - Mike_Blue_30573
Thanks for the Feedback you guys. That TCL switch rocks.
Is there any other resources available for TCL command
structures?
Thanks - You can always refer to the Tcl Reference Manual
http://tmml.sourceforge.net/doc/tcl/
Keep in mind that we do not support the full feature set of the language such as the I/O routines but you should be fairly safe in using any of the control, string and list features.
Also, we've added our own extensions to help with certain common operations (findstr, substr, getfield, etc). You can check these out in the BIG-IP product documentation or in the Docs and Tips section of DevCentral.
-Joe - Mark_Crosland_1Historic F5 Accounthttp://www.tcl.tk/doc is another good source of information
