jcarpenter82's avatar
jcarpenter82
Dec 18, 2024
Irule using a data group to bypass header injection
Trying to do a basic irule that looks at a data group and bypasses the header injection based on the data group uris. Been messing with the below but getting multiple errors when adding the top lines to bypass the existing irule posted below. Datagroup would be the uribypass
    if { ([class match [HTTP::path] starts_with "uribypass"]) } {
        exit
    else {
        if { !([HTTP::header exists "test-Proxied" ]) } {
            HTTP::uri /test[HTTP::uri]
            # Inject custom header
            HTTP::header insert test-Proxied 1
  • Hi jcarpenter82
    You are close, but missing a closing bracket on the first if statement, and you want return, not exit there. I think this is what you're after:
        if { !([class match -- [string tolower [HTTP::path]] starts_with uribypass] || [HTTP::header exists "test-Proxied"]) } {
            HTTP::uri "/test[HTTP::uri]"
