Christopher_167
Jan 21, 2012iRule to use a pool based in incoming port ?
Hi, Anyone have an iRule that uses a pool based on the incoming port ?
(Note: I'm an iRule n00b. In fact this is my very first attempt at even thinking about iRules. So if you will please humor me...(searching didn't find an easy answer so I have begun reading documentation))
I have currently setup a many virtual servers, all listening on the same IP, on different ports. Each port is associated with a different pool. All of the virtual servers perform the exact same function which is to just FastL4 to the pool. My pools contain only a single node. In essence, this is a way for me to intentionally hit a single server from the outside.
I'm thinking that perhaps I could instead have an irule that handles this far more elegantly. Has anyone ever done something like that?
What if I create pools with names that contain port numbers.
For example:
pool_101
pool_102
pool_103
And then perhaps create an iRule that says something like:
$destination = "pool_"$inboundport
forward traffic to $destination
Any ideas on how to elegantly redirect traffic to a single node based on the incoming port?
--CL
- hoolio
Hi Christopher,
You can try something like this:when CLIENT_ACCPEPTED { Try assigning the pool based on the client destination port If the pool assignment fails, use the VS default pool if {[catch {pool pool_[TCP::local_port]} result]}{ Pool did not exist, so log the value for testing The VS default pool will be used log local0. "pool_[TCP::local_port] doe not exist" } else { Pool assignment succeeded } }
Aaron
