IRULE to terminate connection after certificate verification
to minimize CCU usage and the desired outcome being to terminate connection after certificate verification, We can use the SSL::handshake event.
The idea behind the irule is to terminate connection once the ssl-handshake is completed and the logic is as follows
when SSL::handshake is complete { for a given ip-address (here you would check an incoming IP address against a pre-determined(known) address [ for example ip.addr == 10.125.0.3]) reject if ip-address matches then the iRule would terminate the connection. }
This way we would immediately release the connection and would not have to wait for 900 seconds. More importantly it would not affect your Access policy
Could you please sample irule on this
- R_Marc
drop should do what you need. I, personally would do a class match against a data-group for this. Since a data-group is a structured list, so there is less risk in adding/removing that updating the iRule itself.
Not sure why you'd wait util after the ssl handshake though, if you know the IP is bad, just drop it and CLIENT_ACCEPTED, though you can do it in most other events, I believe. That being said, this is probably better handled at a firewall.
ltm data-group internal drop-list { records { 10.125.0.3/32 {} } type ip }ltm rule drop-list-rule { CLIENT_ACCEPTED { if { [class match [IP::client_addr equals drop-list] } { drop } } }
