WAF_Monkey's avatar
WAF_Monkey
Dec 02, 2020
Solved
iRule to reference data group for whitelisting IP
This has got to be simple but I can't figure it out!! :-(
Can anyone help me to write an iRule that will reference a data group list of IP addresses I want to whitelist on ASM? I don't want to deny IP's that aren't on the list, just to never block those on the list.
Thanks!
Tony
  • You can log the unblocked requests from within the local traffic policy. (I had log statements in both my rules, but removed them for the answer above.) There is a log action that can be added on the disable ASM rule. For example:
    ltm policy disable_asm_for_select_IPs {
        controls { asm }
        last-modified 2020-12-03:15:50:12
        requires { http tcp }
        rules {
                actions {
                    0 {
                        asm
                        disable
                    1 {
                        log
                        write
                        facility local0
                        message "tcl:ASM disabled for allowed IP [IP::client_addr]"
                        priority info
                conditions {
                    0 {
                        tcp
                        address
                        matches
                        datagroup no_ASM_IPs
            enable_asm_for_all_traffic {
                actions {
                    0 {
                        asm
                        enable
                        policy /Common/lab_8_manual
                ordinal 1
        status published
        strategy first-match
  • You can add whitelist ip in WAF/ASM under ip/subnet exception list. It will give more flexibility then iRule... Hope it will work.
    Thanks​
  • I have about 450 IP addresses to allow. I already have the data group list on the box, just need an iRule to reference it. Thanks.
  • you can try something like this... Not tested yet. Please test in non prod device.
    when CLIENT_ACCEPTED {
       if {[matchclass [IP::client_addr] equals bypass_asm_class]}{
          set disable_asm 1
          #log local0. "[IP::client_addr]:[TCP::client_port]: Client matched bypass_asm_class datagroup."
          set disable_asm 0
          #log local0. "[IP::client_addr]:[TCP::client_port]: Client did not match bypass_asm_class datagroup."
    when HTTP_CLASS_SELECTED {
       if {[HTTP::class asm]==1}{
          if {$disable_asm==1}{
             log local0. "[IP::client_addr]:[TCP::client_port]: Disabling ASM for this request."
             ASM::disable
             log local0. "[IP::client_addr]:[TCP::client_port]: Not disabling ASM for this request."
             ASM::enable
    Set the log according to requirements and later disable it
  • The HTTP_CLASS_SELECTED event has been deprecated. Instead, you can use a local traffic policy to selectively enable and disable ASM, as Samir showed, using an IP address data group to make the comparisons. For example:
        controls { asm }
        last-modified 2020-12-03:10:38:38
        rules {
                actions {
                    0 {
                        asm
                        disable
                conditions {
                    0 {
                        tcp
                        address
                        matches
                actions {
                    0 {
                        asm
                        enable
                ordinal 1
        status published
    It's important that the catch-all rule, enable_asm_for_all_traffic, be the second rule in the policy, and disable_asm_for_select_IPs be first. You would assign the local traffic policy to the appropriate virtual server, replacing the default one applied when you enable an application security policy on the virtual server.
    Here is what my internal datagroup looks like. (You can use an external data group just as easily.):
    ltm data-group internal no_ASM_IPs {
        records {
            10.10.10.30/32 { }
        type ip
    I tested this on BIG-IP ASM v15.1.0.
  • Works great on v16, unfortunately I can't log the unblocked requests. Guess that's the lesser of the two evils. Off to dev. Thanks again!
        controls { asm }
        rules {
                actions {
                    0 {
                        asm
                        disable
                    1 {
                        log
                        write
                        facility local0
                        priority info
                conditions {
                    0 {
                        tcp
                        address
                        matches
                actions {
                    0 {
                        asm
                        enable
                ordinal 1
        status published
